This event occurs when an MLAG node receives a checkpoint message from the peer with ingress VLAN IP address information that does not match any of the MLAG VLANs configured on the local node.
Ensure that MLAG VLANs are configured with correct IP addresses and mask length on MLAG peer nodes. If the IP addresses do not match for MLAG VLANs then PIM may not function as expected. Contact technical support with output from following commands: 1. show pim 2. show vlan 3. show pim cache detail
Info
Unknown IP address %ip%/%mlen% in checkpoint message for S %src%, G %grp%
| Name | Type |
| src | IPaddrN |
| grp | IPaddrN |
| ip | IPaddrN |
| mlen | uInt |
